    Dec 2005
    I'm trying to backup game disc with Nero 7 and had no luck so far. I have 17 grandchildren and they hammer the disc.
  2. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    I think you're in the wrong forum. you're probably better off posting in the "Newbie / General discussions" forum.
    https://forum.videohelp.com/viewforum.php?f=10
    glad to help.
  3. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    Try a google search for "Playstation 2 backup" . There are tons of sites that go into very extensive detail about it. This site is primarily video (hence, videohelp.com)
    Mar 2003
    Few questions
    1. Is your ps2 modified?
    (ps2 must be modified somehow to play backups)
    2. what type of media (are you using brand, +, or -)
    (could be the type of media is not compatible)
    3. What versioin ps2 do you have
    (this makes a differnce on the type of media that would work
    4. are you trying to burn dual layered games on single layered media
