I'm using Ulead Systems' Video Studio 9, and can't seem to be able to put 2 hours of video to fit on a DVD for some reason. The most I've been able to fit is around an hour and a half (97 minutes to be exact). I first capture the video from my Camcorder (Mini DV), then encode to MPEG2, using 80% Video Quality Compression, and 6,000 Bitrate, and for some reason once the video's finished, it tells me that it cannot fit on a DVD and must re-convert to 5,000 Bitrate.
But when I then encoded another video at the 5,000 bitrate, it only can fit 90 minutes. What am I doing wrong here?
_____________________________
Thank God For Jesus Christ!!! -
If you use pcm/wav audio you can only fit around 90 minutes using 5000kbits.
Lower the bitrate if you want to fit more minutes/dvd. Or use compressed ac3 audio or mpa/mp2 audio, pcm/wav is 1536kbits and compressed audio around 192-224 kbits.
Use a bitrate calculator to calculate the bitrate and set it manually, www.videohelp.com/calc
Or use dual layer media. -
I don't know the software, but anything that bases it's encoding decisions on a quality % makes me suspicious.
The only way to do this is with a bitrate calculator. Determine what bitrate you require to fill (or squeeze) a given running time into a given space. Use this number when encoding. Assuming, for the moment, that VS9 allows you the freedom to enter a bitrate, override it's pointless, imaginary quality based numbers with something derive via maths and science, and you will get it to fit.
There are many bitrate calculators around. This site provides a hand, online version here. https://www.videohelp.com/calc.htm
According to it, with a single 224kbps audio track, you have an average bitrate of 4853kbps to encode your video with.
Of course, it you use something silly like LPCM audio, you wont get 2 hours on without it looking like crap.
What audio format are you uaing ?Read my blog here.
I'm using the LPCM audio, so that may be the reason. Problem is that LPCM is the default audio when capturing the video. What audio do you recommend I use? and how does it compare in quality to WAV/PCM audio? Thanks.
Putting photos in timeline and editing their length. Sony Movie Studio HD
By jjzapp in forum EditingReplies: 1Last Post: 4th May 2011, 22:37 -
Best Option for exporting 3.5 hours of video for DVD
By buddyreid in forum MacReplies: 5Last Post: 22nd Sep 2009, 00:57 -
Putting a 7.6 GB video on a DVD
By cameraz in forum Newbie / General discussionsReplies: 20Last Post: 18th Jul 2009, 15:24 -
Hours of Music without Hours of Video Data in DVD Architect
By Guff22 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2008, 22:23 -
Putting together amateur video on DVD
By Spring Rubber in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2007, 15:12
