  1. Member pchan's Avatar
    Mar 2003
    Singapore
    Hi Everybody,
    Before I burn my first DVD+R DL with DVDLab Pro and Nero, I would like to confirm with the expert here whether the layer break features in DVDLab Pro works with Nero.
    If yes, would it be like setting the layer break in DVDLab Pro after compiling and burn with Nero.
    Thanks in advance.
    Apr 2004
    Miskatonic U
    I believe the main problem with Nero is it ignores everybodies layer break and puts one where it want to. I don't think it matters what you author with, Nero screws the layer break. General suggestion is to use something else. Record Now Max 7.3 has a great rep for DL burning. Prassi ONES and CopytoDVD also seem to be good. The other option that still seems to work well is to author with the layer break, compile the disc, create an ISO, and burn with imgburn.
    Read my blog here.
  3. Member pchan's Avatar
    Mar 2003
    Singapore
    Thanks.
    Can I do it with DVDLab Pro and imgburn ? If yes, my next question is whether imgburn can co-exist with Nero ? From my experience, Nero + other burning software with cause BSOD.
    Apr 2004
    Miskatonic U
    If DVD Decrypter can them imgburn can. ImgBurn is an enhanced version of the DVD Decrypter burning engine. Use imgtools classic to create an ISO from the output that DVD Lab Pro creates.
    Read my blog here.
  5. Member e404pnf's Avatar
    Dec 2004
    Warmington on Sea
    Originally Posted by pchan
    .... my next question is whether imgburn can co-exist with Nero ?
    Yep, no problems. I've got both Nero 7 and imgburn installed and use both without any problems.
  6. Member pchan's Avatar
    Mar 2003
    Singapore
    Thanks folks. Will post my result once I done with it.
