I'm trying to encode a vcd file to avi using the default xvid 1 pass compression rate, anyways I have a 9800 aiw, 1 gig of ram, 1.9 ghz, have the process as high priority, not using the comp at all during the encode and yet its only doing 70-80 fps ? Why is this ?
70-80 fps seems very fast to me, doing mpg to XviD encoding...
/Mats -
What kind of frame rate did you expect? That doesn't sound out of line depending on what frame size and other settings you're using.Originally Posted by StoneColdWhat
There's not much point in running at high priority. It simply makes the computer unusable and doesn't increase rendering rate by any significant amount. I almost always run at idle priority and use the computer for light tasks like web browsing while encoding (like right now). If you're not doing anything else with the computer, a process running at idle priority will get just as much CPU time as it would at high priority. -
Hah, my machine does only like 7-8 fps. Who are you to complain?
lol I dont encode much I was expecting atlease 100 or so like I get in games :O
HandBrake Low FPS
By Guess Who in forum Blu-ray RippingReplies: 6Last Post: 17th Oct 2011, 11:27 -
Best Encoder when encoding with low bitrates
By MI6 in forum Video ConversionReplies: 6Last Post: 27th Nov 2010, 20:37 -
Low fps
By dylanvega123 in forum Video ConversionReplies: 8Last Post: 15th Jul 2010, 03:47 -
FPS during encoding process
By godwentpunk in forum Newbie / General discussionsReplies: 0Last Post: 8th Sep 2009, 12:43 -
Vista64 playing wow with low fps
By johns0 in forum ComputerReplies: 13Last Post: 28th May 2007, 19:57
