Taking footage with my camera, using new DV tapes (tdk, sony, etc). Getting two dirty problems -- actual specs of dirt that look like spots throughout the screen, and a "glare" like grime, or like a milky screen across. I ran a DV head cleaner tape through 3 or 4 times but I assume this dirt problem is deep inside the camera, in between the lenses as I also took the front circle lens cap off and cleaned as far as a normal person can reach into a camera.
My camera is a JVC- GR-DVM75. Doesn't appear to be any easy way to get deep inside the camera without full dissasembly. Anyone think this is likely a head problem, or the lenses which I suspect? Any experiences on it? Thanks much.
Is the camera new or old? Have you tried transferring some footage to PC and onto DVD and checking on a TV? Have you had the camera stored in any enviornments where it could have been exposed to more dust or dirt than normal? If it's new I'd suggest a return if you can. If not see if there's a local camera or electronics repair shop.
Hi coffeecup-sf,
Try searching / posting in the forums over at www.camcorderinfo.com - it's another good site that may help.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Those head cleaners are responsible for breaking more cameras than helping them.
Offhand, I'd suggest a professional cleaning of the heads for beginners.
Time for an HD cam.. Last cam was Pana. DVC80.. Next will be?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 25th Nov 2011, 19:35 -
How to increase when TC OR CAM DVD to Tc or Cam rip
By antonymaheshca in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2010, 14:42 -
footage from 5d Mark II mixed with XLII footage
By segan in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2010, 15:24 -
Producing DVDs from HDV footage
By lasereyes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Mar 2009, 18:25 -
Loading footage captured on DV tape, shot with HDV cam??
By Anthalloran in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 8th May 2008, 11:04
