I use lordsmurf's guide for using PowerVCR II to capture video at 352x480 for easy authoring on to DVD.
However, I blew up my registry a while ago. I reset the appropriate registry keys according to lordsmurf's guide. But after capturing a few things and then trying to author them, I found that they got captured as 176x480! Now TMPGEnd DVD Author won't recognise them.
I've fixed PowerVCR II and tested it, and I'm now capturing at 352x480 again. But is there any way to "upconvert" the stuff I captured at 176x480 to 352x480 so I can burn them? I don't care if the quality isn't as great; it's just stuff I've taped off broadcast.
Thanks!
Robert
Converting 720x480 to 352x480
By Regor21 in forum Video ConversionReplies: 8Last Post: 9th Mar 2011, 11:34 -
Bitrate 720x480 vs 352x480 concept question
By CaZeek in forum Capturing and VCRReplies: 15Last Post: 8th Oct 2010, 13:08 -
How to patch 352x480 MPEG-2 to 720x480
By moxiecat in forum Video ConversionReplies: 1Last Post: 1st Mar 2010, 14:43 -
720x480 or 352x480 ?
By StoneColdWhat in forum Video ConversionReplies: 7Last Post: 7th Aug 2009, 09:16 -
352x480 Half D1 Mpeg2 to Divx - How do I keep proper aspect ratio (40:33)?
By stizz in forum MacReplies: 16Last Post: 8th Feb 2008, 02:24
