I have a NEC ND3500AG dvd burner that burns double layer discs. I purchased some Ridata DVD-RDL double Layer discs but Nero doesn't seem to recognize the whole 8.5g storage capacity. It only recognizes the normal DVD size. Did I buy the wrong media? Thanks in advance!
Results 1 to 9 of 9
Too little info. Which firmware are you using? Which Nero version number are you using?
2.16 is the shipped firmware for the 3500. Download the latest 2.19 or 2.1a firmware for greater media compatibility and fully supported 4x DL write strategies.
The NEC 3500 will burn DVD+RDL but not DVD-RDL.
http://liggydee.cdfreaks.com/popup/3500/specs
Liggy & Dee do not list any firmware updates for the 3500 to burn DVD-RDL media.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
would you happen to have a good address for the firmware updates, i did a google search and came up with broken links :/
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 16:13 -
Double Layer Issue That Is Beyond Bizzare..I think I killed the burner
By mrjoelabs in forum DVD RippingReplies: 5Last Post: 1st Sep 2010, 08:49 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 13:26 -
DVD+R9 Double Layer first burn: problems with layer switch
By Edmund Blackadder in forum DVD RippingReplies: 400Last Post: 4th Oct 2009, 11:27 -
What burner should i use to burn double layer disks
By Trident5 in forum DVD & Blu-ray WritersReplies: 8Last Post: 25th Sep 2007, 05:51
