Okay,
I'm new to this forum; but not new to copying movies; and I just recently have been jumping from AfterDawn.com to VideoHelp.com; and now I've finally come across a problem w/ copying from VHS to DVD. What I use is a standalone CyberHome DVD Recorder, a Panasonic Quasar VCR; and a DVS-2 Video Stabilizer. I'm also using FujiFilm DVD+R discs. And the problem I have come across is that when I put in a VHS tape and hit record, the picture will be fine; but every once in a while it will do this sort of jitter or glitch in the picture.......so my first thought was that my Video stabilizer had some loose composite video connnections, causing it to "flicker" , but I soon went on to believe that it's the inputs on the back of my VCR that are loose; so I tried to look for a screw on the back that could tighten these inputs so maybe it would keep them from making the picture all jittery. But, I failed to find some, so I was wondering if anybody's encountered this same problem and has an answer. Thank You.
Results 1 to 1 of 1
Problems with capturing using ION VCR 2 PC
By mostly_useless in forum Capturing and VCRReplies: 0Last Post: 21st Dec 2011, 19:16 -
Looking for Good VCR for Capturing
By zerowalker in forum Capturing and VCRReplies: 0Last Post: 28th Nov 2011, 18:56 -
Need Help Urgently Capturing from SVHS VCR
By Hairykiore in forum Video Streaming DownloadingReplies: 9Last Post: 4th Aug 2011, 20:26 -
VCR capturing question?
By s3r19lk1ll3r in forum Capturing and VCRReplies: 1Last Post: 17th Oct 2010, 22:26 -
Having problems capturing from VCR
By Confused Chimp in forum Newbie / General discussionsReplies: 5Last Post: 29th May 2007, 03:41
