Hello
My son has a lot of animes that he downloaded and wanted burned to DVD. In trying to get as many as possible on DVD and in episode order
running into problems with different codecs/video resolution. Maybe even audio but not sure on that
Most are DivX3 Low Motion.
However there are some with different codecs. Like S-MPEG4 v3.
Some are 640x480 and others 512x384
In each folder is anywere from 15 to 25 files.
So using MovieFactory2 or The Film or even avi2dvd choke due to these incompatibilites.
Is there a program or something that can be done to make them all the same video resolution/video codec etc. ?
Also why is it what using the file explore all the files in a directory will add up to say 4.2gig but when I put them into MovieFactory I can only get 4 of them (each file is about 175.500KB). The disk indicator says 4.2 gig after just 4 files. ?
Mark
Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.
geesh what a waste of a reply and my time to have to come view it.
Be who you are and say what you feel because those who mind don't matter and those who matter don't mind. -
Why - he gave you the answer - DivxtoDVD, and some sage advice. Most of what is available for download is a) in contravention of the rules of this site to discuss because it is copyright material, and b) is of dubious quality, especially when expanded to DVD resolutions.
It is also obvious by you post that you have so far only tried the path of least resistence in what will only result in a low quality outcome. A little more time and searching on your part would have delivered to you the answers you seek, but they all involve multiple tools and a lot more effort on your part. The results of which would be a substantially better quality output. If you want the results to be more than a blur of ugly pixels, I'd suggest reading this guide -> http://members.dodo.com.au/~jimmalenko/AVI2DVD.htm
You would have to follow it for each seperate clip, and it will take quite some time, but if you wan't something watchable. . . . . . .Read my blog here.
Well, from reading your question you clearly can't be bothered to put in more than minimum amount of effort necessary, so the old saying goes... You get what you put in. And since you ain't gonna put much in...
Joining mp4 files (same fps and codecs but slightly different resolutions)
By AshleyQuick in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2010, 21:28 -
Multiple Files & Resolutions In Tempgenc Xpress 4
By TufrThanu in forum Video ConversionReplies: 0Last Post: 9th Aug 2009, 14:21 -
Confusion Among Formats & Codecs (Converting DVD for HDD/PMP Use)
By sirryan in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2008, 14:42 -
Movie in 2 avi files but with different resolutions
By LaLuna in forum Video ConversionReplies: 4Last Post: 24th Nov 2007, 21:00 -
Help playing these two files and advice on codecs!
By tigerb in forum Newbie / General discussionsReplies: 5Last Post: 14th Jul 2007, 10:18
