i was looking at portable vcdplayers and i can apon this vcdplayer that says its dvcd compatible. and i'm wondering whats that. I've never herd of it before, so can someone tell me what it is?
The player that plays it is called "Supertek MP-2001V". http://mp3playerstore.com/buy_it_now__/mp-2001.htm
@Greg 12: It is neither.
A DVCD uses standard VCD compliant MPEG files. It manages to fit more video in (according to hype, up to 120 min but I have never heard of a real "DVCD" disc much more than 90 min) by a stamping trick -- the spiral track of the CD is stamped tighter to fit in more data.
In a way, burning VCDs onto 90/99 min media could constitute "DVCD" though nobody calls it this of course.
The last several posts on "DVCD" involved the same question. If you search the forums for "DVCD" you will find those posts. Some of those posts also had external links I believe.
Regards.
Michael Tam
w: Morsels of Evidence
Whats beter than SD600?
By jupita in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 21st Jun 2011, 03:00 -
Whats an Rpex codec and where can I get it
By Bob2541 in forum Software PlayingReplies: 7Last Post: 22nd Feb 2010, 00:20 -
whats authoring?
By templedog in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2008, 01:28 -
Whats in the pipeline?
By 2Tents in forum SVCD2DVD & VOB2MPGReplies: 12Last Post: 7th Jul 2008, 12:39 -
Whats Wrong With This Forum?
By gealto2 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 27th Jun 2007, 19:11
