Results 1 to 10 of 10
    Sep 2005
    sweden
    packard bell 450 pro got memory in it thats supports upgrade and codecs but can i download codecs in it. how and what codecs can i download into the dvd.
    Dec 2004
    Australia
    Sounds like you mean that it supports firmware updates. Go to their site and see if there are any firmware updates. Should also be update instructions. Also generally a CD is required, not DVD.
  3. Banned
    Freedonia
    Sarmin - your question doesn't make any sense. What do you want? To upgrade the firmware? To install codecs? You can find some firmware upgrades at
    http://www.rpc1.org
    Codecs can be downloaded at http://www.doom9.net
    I am amazed that Packard Bell is still in business. I looked at their web site and it seems that while they long ago abandoned the North American marketplace, they still sell their products in Europe and other places. Their PCs weren't very good and used non-standard components (meaning you could not buy off the shelf stuff and make it work in their PCs - everything had a proprietary connector), so they lost marketshare in the US and left our market.
    Sep 2005
    sweden
    install codecs on the dvd how do i do that. so it can play those codecs to
    Sep 2005
    sweden
    i want to upgrade my dvd with new codecs
  6. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    You don't put codecs on a DVD.
    What codecs do you want? ... OR ... What is it you are trying to do?
    - John "FulciLives" Coleman
    Nov 2002
    PB's only in business in Europe it seems. And they use the brandname on electronics over there. That model number, according to Google, is a standalone DVD/DIVX player.
    Firmware upgrades are here:
    http://service.packardbell.fr/items/?PibItemNr=instr_pbdivx450_firmwareflash&PibItemPa...orm_divx450pro
    Sep 2005
    sweden
    i want x264 but my dvd-player doesn't support that but i got extra memeory and on PB they say that you can download new codecs into the dvd-player. so it can support that codec to. how do i do to get the dvd-player to support x264 for an example or other codecs
    Dec 2004
    Australia
    The chipset wouldn't be able to handle AVC, none that are currently out can so it can't handle x264. To handle x264 you would need a chipset that can decode HP AVC.
    Sep 2005
    sweden
    what can it handle that my dvd don't got. can it handle nero cinema asp?
