i was wondering if i should buy a dreamcast and convert my divx's to dreamcast format(there's a link for it on the tool section, on how to do it), but i don't know if it works or not. can some one tell me? thanks
It doesn't sound like a good idea to me. Dreamcast VCD playback is not very good at all, and converting DivX to VCD usually produces bad-looking results. If I were you I wouldn't waste the time to convert DivX to blocky VCD and then watch it on Dreamcast.
An Apex DVD player costs just $30 more than a Dreamcast anyway... -
umm... i not talking about vcd converting. i'm talking about Dreamcast format .sfd (or something), i wondering if it works.
I havent used that dreamcast divx program yet but the dc has really bad playback anyway. I dont believe that prog converts the vid into dc video formats but into a divx format that will play with the software in the d/l kinda like that gyplay prog does with mpegs. I wouldnt suggest bothering with it unless u just felt like experimenting.
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 13:20 -
Dreamcast video
By Avatar in forum Newbie / General discussionsReplies: 24Last Post: 10th Sep 2009, 20:38 -
Unlikely console revival - Dreamcast ??
By Noahtuck in forum Off topicReplies: 9Last Post: 8th May 2009, 20:44 -
Is the Playstation 3 destined to go the way of the Sega Dreamcast?
By yoda313 in forum PollsReplies: 32Last Post: 21st Jan 2009, 18:18 -
Encoding Dreamcast onto iMac for fullscreen viewing
By karas in forum MacReplies: 5Last Post: 13th Nov 2007, 10:00
