I know that i can choose a custom sized avi in avi.net settings. However, is there any way to set the program to split my final file into 2 segments, like FairUse Wizard will do for you? Or, can anyone point me in the direction of a tool that will split avi?
-> VirtualDubOriginally Posted by MistaED
/Mats -
Is there any way to save it to the original xvid format though? Every time I attempt to save my cut segments, I end up with what appear to be uncompressed avi.
put VirtualDub into Video -> Direct Stream Copy mode. The default for Audio is Direct Stream Copy, but check it anyway.
Why no subtitles in AVI.net v3.5.0.0
By stankley in forum DVD RippingReplies: 1Last Post: 11th Sep 2011, 09:40 -
avi.Net Problem: Not producing an .avi file
By Johnathan K in forum Newbie / General discussionsReplies: 10Last Post: 5th Feb 2011, 15:22 -
avi.net - No Subtitles
By Quanti in forum Newbie / General discussionsReplies: 6Last Post: 13th Jan 2009, 15:37 -
Need instructions on how to use avi.net
By snafubaby in forum DVD RippingReplies: 1Last Post: 21st Dec 2008, 18:05 -
For VOB files to AVI, I use avi.net . . Question
By nhbfan12345 in forum DVD RippingReplies: 4Last Post: 10th Sep 2008, 23:02
