    Jan 2006
    n.ireland
    which are the correct settings to set up video capture to transfer to dvd
    disk in the ntsc mode of viewing in most movie capture devices, i.e.
    numbered settings. and video quality or custom quality.
    we neeed more information!
    what is you capture device?
    what tool(s) are you using?
    are you capturing in pal and want to convert to ntsc? or capturing in ntsc?
    Jan 2006
    n.ireland
    My movie software is Magix Movies on 2.0 cd & dvd . i can transfer video
    in Pal okay at 25 frames a second , but i would like to know the correct
    settings for ntsc i.e. the correct bit or bite rate and should i set the video
    quality to video quality or should it be custom quality for best results.
    what settings would most users set for the ntsc format ?.
  4. Everything is the same for NTSC except the frame rate is 29.97 fps, and the vertical height of the frame should be 480 or 240.
