Hi,
I saved some DivX files using VirtualDub & Divx 6 encoder, and for some reason when I try to import it into VegasVideo only the audio track appears in the timeline, any ideas or suggestions?
The divx files play fine in other video players.
output as huffyuv or dv-avi in virtualdub instead.
or read https://forum.videohelp.com/viewtopic.php?t=251153&highlight=vegas+divx -
Thankkkkkk youuuuuuuuuu
Looks like HuffyUV files are being read fine in Vegas, but now i have a file size problem. I'm working with a 3 minute music video that is about 150mb, after opening in VirtualDub and using huffyuv to save the new .avi file it is coming out 1-2gigs large, i know this has probably been discussed, but i couldn't find it in the the forum, which settings are best with huffuv so that i can keep the size around the original?
i basically just want to maintain the quality and keep the size around the original. I don't want to lose quality though cause i need the video for broadcast. -
I would also like to add, if i try to select direct stream copy, and then save the video file, i get an error message
so that doesn't appear to be an option
Need a little help with Sony Vegas and Divx
By 1Wolf in forum EditingReplies: 1Last Post: 16th Jul 2011, 09:08 -
Problems importing Quicktime movies into Sony Vegas
By matthewjohn23 in forum Newbie / General discussionsReplies: 8Last Post: 11th Feb 2011, 20:31 -
Converting MPEG-2 to something editable?
By Texas in forum Video ConversionReplies: 1Last Post: 14th Apr 2010, 16:53 -
Sony Vegas rendering problem. Movies get much larger than estimated.
By Night-Blade in forum EditingReplies: 4Last Post: 2nd Jul 2008, 14:57 -
DVD to something editable
By investingstuff1971 in forum DVD RippingReplies: 2Last Post: 10th Jun 2007, 10:58
