alot of the svcd/vcd movies i download from newsgroups are already turned into video_ts folders and i was wondering if in the next version you could add the ability to add the video_ts folder or the main .vob's as assests to make into another dvd.
if there is a simple program out there that can do this plz let me know, but if you could add that feature in the next version i would appreciate it!
THANX
SiD
Use VOB2MPG and add the resulting files to 'assets'.
https://forum.videohelp.com/viewtopic.php?t=252033
Feature Request - Read ISO Images
By Aberslam74 in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 23rd Mar 2011, 13:45 -
Feature REQ:True batch encode
By tszpara in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th Jan 2010, 04:30 -
How to add permanent subs inside a semi-transparent box?
By majin_buu in forum SubtitleReplies: 5Last Post: 9th May 2009, 11:43 -
create video to different formats from images (read reason inside)
By kebrus in forum Newbie / General discussionsReplies: 3Last Post: 23rd Dec 2008, 17:56 -
Make a driver read from outside to inside
By frozenwind in forum Authoring (DVD)Replies: 1Last Post: 15th May 2007, 16:29
