How can I make this mpeg dvd compliant, so it will play correctly in my dvd player? Currently I am using TDA to edit, then copytodvd to burn to disc. Problem is since the source is 480x480, which is not dvd compliant, my dvd player isn't playing it properly. Right now when played the video is off centered.
What program can make this mpeg(480x480) into one that is dvd standard ? Freeware would be a plus, but all ideas welcome. Thanks
Results 1 to 17 of 17
What We Do In Life, Echoes In Eternity....
Top left corner of this page is a link marked What is DVD ?
Have a read of to find out what is compliant. Use g_spot to tell you what framerate you have, from there you can choose a resolution. I would suggest half-D1 will be best.
Your other coice is to put a border around it to bring it up to spec.
Either solution requires re-encoding.Read my blog here.
You could use the TMPGEnc encoder to convert your MPEG to DVD compliant MPEG-2. Choose the correct DVD template and re-encode.
However you have to take care of audio. DVD will usually have AC3 audio. So you may need the AC3 plugin for TMPGEnc. Or convert to LPCM because some DVD players may not play MP2 or MP3 audio.When I was born I was so shocked that I could'nt speak for 18 months. -
You could also try svcd2dvd or it's free cousin svcd2dvdmpg, or just DVDPatcher.
/Mats -
The mpeg is a show recorded off Tivo.
I tried TMPGEnc encoder but it says the file is not supported?
mats.hogberg how would I just use dvd patcher?
Here is the info that dvd Patcher V1.06 gives me:
Size 480x480
Aspect Raio 4:3
Framerate 29.970
bitrate 3500000What We Do In Life, Echoes In Eternity.... -
Quite a while ago (a year or so ago) I wonderded about this same thing. At that time I had an ADS instant DVD usb device that either did dvd vcd or svcd. The 1/2 ht DVD would require hours and hours of computer time after the initial capture. What I did and I was surprised that it worked was capture in SVCD mode using m2v and 48 audio. Then ran it thru an older version of muxman and within 3 or 4 minutes I had a Compliant ? DVD that would play on my stand alones. I was amazed how quick and easy it was.
Patch the size to any DVD compliant size, like 352x480. That will make the mpg accepted by most authoring apps, and most DVD players will play it as if it was a regular DVD.Originally Posted by Denvers Dawgs
/Mats -
Do I patch just the first header or the whole thing?Originally Posted by mats.hogbergWhat We Do In Life, Echoes In Eternity....
The first header, but be sure to check out your SVCD-DVD on various players, as this method does not work well for all players if you want to put more than 1 SVCD on a DVD. Some players will play the first SVCD part fine, but then have the rest of the files wrong, only filling part of the screen. Get SVCD2DVD and make your life MUCH easier. For about $18, it's well worth the cost.
The link below shows a method that also works great, but is MUCH more time consuming than using SVCD2DVD
https://www.videohelp.com/forum/userguides/154453.php -
I use the DVDPatcher method. I patch the entire file and all of the files if there's more than one. After authoring be sure to patch the movie VOB's (but not the menu VOB) back to 480x480. Quick and easy.
I author the patched mpegs with TDA which upsamples the audio for you."Art is making something out of nothing and selling it." - Frank Zappa -
Exactly as shown. And I've never had a reason to patch it back. (But if you do, patch it back from 352 to 480 width again.) Only anomaly is that TDA chapter thumbs are squished, but I can live with that. (Or ditch the chapter menu.)
/Mats -
It's a non-standard format so each player will handle it different (and some not at all). If I don't patch it back to 480x480 then I can't get a proper display for the movie on my player. It's a quick adjustment which makes it acceptable for some players.Originally Posted by mats.hogberg"Art is making something out of nothing and selling it." - Frank Zappa
capturing dvd compliant mpeg-2 with vdub
By wolfdogg in forum Capturing and VCRReplies: 0Last Post: 10th Jan 2012, 20:06 -
How do I make an MPEG-2 dvd compliant file into a authored dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 12th Mar 2009, 16:10 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 11:46 -
question about VOB compliant files to make DVD
By jimdagys in forum Authoring (DVD)Replies: 3Last Post: 25th Nov 2007, 02:05 -
No audio in dvd compliant mpeg 2 files
By Bertieboo in forum Video ConversionReplies: 6Last Post: 14th Nov 2007, 16:35
