Anyone know how to fix this problem i load a .mp4 video to convert to dvd and svcd2dvd crash. I tried to differ mp4 videos and it still crashes.
Results 1 to 21 of 21
Which version/build are you using? Make sure you are using the latest release.
Is there a log file or error message?
What is the audio format of the .mp4?Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
I'm using the lastest release and build. I know its a (H.264) mp4 video. what ever that means. As for the audio its AC3 i belieave.
I'm also having this problem.
Anyone knows how to 'convert' mp4 to dvd?
Thanks. -
aac audio will cause this.
Dwight
- Herm Albright
I have never used this type of file (mp4). My suggestion would be to try and open the file in VirtualDub (I don't know if it's supported). If the file plays in VirtualDub, try saving it with WAV audio (video = direct stream copy, audio = full processing mode). You will enup with a larger file that you may now be able to use in SVCD2DVD.
Dwight
- Herm Albright
Ok, I used mediainfo:
3GPP: 1.21 GiB, 1h 50mn
1 video stream: H.265
1 audio stream: AAC LC -
Originally Posted by Jikchung
As far as I remember AAC audio is not supported by SVCD2DVD.
https://forum.videohelp.com/viewtopic.php?p=1453264&highlight=aac#1453264Dwight
- Herm Albright
Indeed. I am working on it.
I'm having a similar problem, but the error is not from SVCD2DVD. When I pick an asset that is an MP4 file, I get an ffmpeg.exe error.
I had to dload ffmepg in order to get WMP to play MP4 files (and they play just fine), so I'm not sure why it would crash when an MP4 file is added as an asset to SVCD2DVD.
I just dloaded and installed the latest build BTW...so no need to ask ChrissyBoy
Oh yeah...I checked the MP4 file using AVICodec and all I glenaded from that was the audi and video codecs were unknown
Any insight would be handy as my assets are just taking up drive space right now.
Cheers -
As above, it's probably AAC audio. Check the files with Gspot.
Dwight
- Herm Albright
Try MPC and then look at the properties (File->Properties)
Originally Posted by ChrissyBoy
Video: MPEG4 Video (H264) 576x320 [GPAC ISO Video Handler]
Audio: AAC 24000Hz stereo 62Kbps [GPAC ISO Audio Handler]
So is there a way around this?
TIA
Cheers -
Any update on when SVCD2DVD will be able to handle AAC audio? I'm running into more and more of these H264/AVC/.mp4 files that have that. It's tempting to download them because the quality is so good and the size is so small but the extra processing I have to do to them to get them to work with SVCD2DVD isn't worth it.
Originally Posted by ssalim
http://www.avidemux.org/ its like virtualdub (i mean its better)
Avedimux Crashes when trying to rotate H264/.mp4 video partially
By jigneshdesai in forum Newbie / General discussionsReplies: 0Last Post: 12th Nov 2011, 06:37 -
SVCD2DVD crashes, HDTV2DVD runs ok
By silicon101 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 11th Jul 2011, 15:32 -
Windows 7 Ultimate - Can't load assets in SVCD2DVD
By ttyner in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 13th Jan 2010, 10:54 -
SVCD2DVD 2.5 Will Not Load
By Rower4VT in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Sep 2009, 13:25 -
SVCD2DVD 2.5.3100.0 Crashes
By boggle in forum SVCD2DVD & VOB2MPGReplies: 16Last Post: 11th Sep 2007, 03:34
