Damm its tight.
The only thing is that it takes so damm long to encode files.
Anyone know a way to speed the process up ?
"Anyone know a way to speed the process up ? "
Yes. Buy a P4 1.7+
Encoding at this resolution takes about 24 hours on a P3 @1000MHZ.
On a P4 1.6 ( what I have ) takes 6-8 hours, depending on the movie. This is using TMPG encoder with SSE-2 instruction set turned on.
Are you encoding from a DVD?, because if you are, the frame rate is FILM 23.97. Not 29.97.
If you are encoding from DVD, does it have to be 23.976? I encoded to that and it seeed alittle like slow motion. I changed to 29.97 and it appears fine. Should I leave it?
ApacheBlow me for faster replies.......
How to patch 352x480 MPEG-2 to 720x480
By moxiecat in forum Video ConversionReplies: 1Last Post: 1st Mar 2010, 13:43 -
0x0055 MPEG-1 Layer 3 will only play on one speaker
By kvn8907 in forum AudioReplies: 12Last Post: 2nd Jan 2010, 22:20 -
Can't play VC-1 29.97fps files in MPC
By Megahurts in forum Video ConversionReplies: 6Last Post: 29th Oct 2008, 20:45 -
Why DVD (720x480) bigger than AVI(720x480)
By psxiso in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 05:50 -
Anyway to capture 720x480 using the Gamebridge and still play?
By Mysteriouskk in forum Capturing and VCRReplies: 0Last Post: 19th May 2007, 13:07
