I have a set of VOB that encompass a DVD. My objective is to edit commericals from the VOB files. I successfully used VOBtoMPG and then MPeG VCR to do one set. It worked awesome. I went to do the second set, but found the end is cut off. It seems VOBtoMPG will not include the VT_01_4.VOB file.
So I thought I would make an ISO file with DVD shrink, then convert it back to MPG or VOB somehow. However I'm stuck on how to do this. Any suggestions?
thanks
steve
you can mount it with daemon tools or open it with ISO buster. Generally, if you want to edit it, ISO is not the best format to save it in. It would actually be quicker to re-rip to file mode.
Or, open the disk image with DVD Shrink, set compression to 'No Cpmression', and back it up to a HDD folder.Read my blog here.
In DVD Shrink can I save it to something other than an ISO file? I'm feeling stupid, but can't seem save it back to the VOB files which I would have loved to have done in the first place. The file structure was downloaded so I can't re-rip. It exists on the HDD, but seems "corrupt" by the way it behaves in VOBtoMPG. I was hoping to redo the structure. To try again. I was messing with putting it back on as an image with Daemon and using DVD decrypter, but sticking with DVD shrink would be much better.Originally Posted by guns1inger
Thanks -
When you select 'Backup' you get a series of options. One is an ISO, or ISO and burn with . . .
One of the other options is Backup to a folder on HDD. This is the one you need to choose to get your VOB files.
Persoanlly, I wouldn't use DVD Shrink to rip - I would use DVD Decrypter, even for unencrypted disks. It is still the best ripper around.Read my blog here.
well don't I feel retarded, look at the pull down menu..........
thanks for the help. that will work.
I had also mounted it with daemon and extracted the file structure with dvd decrypter and then it worked. Stayed in sync too.
thanks again
Help me create an .iso file from .vob dvd files!!
By SlyOne in forum DVD RippingReplies: 2Last Post: 15th Aug 2010, 10:25 -
VOB to ISO
By joshua4 in forum Newbie / General discussionsReplies: 6Last Post: 5th Oct 2009, 07:06 -
Creating ISO from VOB's
By chronic777 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2009, 14:36 -
DVD Shrink to VOB,IFO, BUP and then IMGtool to ISO, bigger than 7GB
By opieandy in forum DVD RippingReplies: 3Last Post: 28th Sep 2007, 16:04 -
vob to iso?
By jree1 in forum Video ConversionReplies: 8Last Post: 20th May 2007, 12:12
