I got a Panasonic DMR-e55 off of eBay and it works great. It came with a universal remote instead of the orginal. Is there any way to change the recording mode without an original Panasonic remote?
If not, I guess I'll have to fork over the $30+ to get one.
Thanks.
Here's another question...
If I were to buy the N2QAKB000010 Panny remote. Could I use that to teach my learning universal remote the recording mode buttons and then use it with the dmr-e55? -
Get a e55 remote from Ebay.com it has a lot of special buttons on it that you won't find on another type of remote. You might be able to order one from Panasonic.
You didnt say what universal remote it is. If the uni remote will program advanced codes you can program the recording mode function to a button. The advanced code for record mode is 105
It's a Philips Universal Learning Remote (PM625S). I looked through the manual...doesn't seem like it does the advanced coding.
picture control on Panasonic dmr e55
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Jan 2012, 16:41 -
How to set correc IR (black level in panasonic dmr e55 and es15)
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 13th Nov 2011, 09:42 -
Panasonic DMR E-20 Remote
By bjm01843 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 18th Apr 2011, 17:59 -
use Panasonic DMR-ES35V with universal remote?
By kar120c in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Sep 2010, 14:14 -
Panasonic DMR E50/E55 drive replacement
By zzucru in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Oct 2008, 13:09
