I captured 4 hrs DV video to computer.
Now I want convert them to DVD format.
I read from DVD-Guides.com that Nero Vision can convert 2 hrs video to DVD.
But so far I can only put 1 hr video on DVD, otherwise it would be oversized.
Does anyone know about DV-DVD authoring?
Here would be a good place to start reading https://www.videohelp.com/convert#4;10
I would also ditch any plans to use Nero to get a decent amount of quality video on a disc. Use a bitrate calculator and a good encoder. At four hours I would consider half-D1. In fact, I would split it to 2 disks at 2 hours each.Read my blog here.
Before we let you do this, you must agree that you indend do destroy the quality provided by your trusty MiniDV camcorder.
I'd hate to see you destroy the only copy of the wedding or baby pics, but it could be you are divorcing and only want a low resolution memory.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Nero Vision xtra
By salohcin69 in forum Latest Video NewsReplies: 0Last Post: 20th Apr 2010, 05:30 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
Nero Vision 5 Help
By luckyboym in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2008, 00:47 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Vision 5
By marioval in forum Authoring (DVD)Replies: 0Last Post: 11th Oct 2007, 13:45
