Results 1 to 10 of 10
  1. Member geohei's Avatar
    May 2002
    Luxembourg
    Hi.
    Which version of VirtualDub must I use in order to be able to play AC3?
    I tried VirtualDubMod 1.5.10.2, but it doesn't play back AC3.
    Or do I need a plugin fior the "regular" VirtualDub?
    Any help would be appreciated?
    Thanks,
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    AFAIK it's nothing to do with virtualdub.
    I'd say you don't have an AC3 codec installed. Try AC3Filter.
    If in doubt, Google it.
  3. Member Safesurfer's Avatar
    Mar 2004
    "Just another sheep boy, duck call, swan
    song, idiot son of donkey kong - Julian Cope"
  4. Member geohei's Avatar
    May 2002
    Luxembourg
    AC3Filter 0.70b is installed.
    Are you sure that VirtualDub requires codecs?
    AFAIK, AC3 needs to be built-in, otherwise AC3 doesn't work. Google showed that there was a VirtualDub version 1.4.8, which had the suufix AC3. However this one didn't play AC3 either.
  5. Member Safesurfer's Avatar
    Mar 2004
    Yes, VDub needs to have the correct codecs installed just like any other program. AC3filter is a DirectShow filter, I know VDub uses VFW codecs, so maybe that's the problem. I use the AC3 ACM Decompressor with no problems.
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Safesurfer is correct - The AC3 ACM Decompressor is what to use. AFAIK, no version of VDub has AC3 decoding "built in".
    /Mats
  7. Member geohei's Avatar
    May 2002
    Luxembourg
    Originally Posted by Safesurfer
    Can I use a regular VirtualDub version (e.g. 1.6.10), or must I use VirtualDubMod (e.g. 1.5.10.2)?
    Thanks,
  8. im pretty sure if you have the acm decompressor, you can use either...i normally use virtualdubmod though, just because it has a few other options that regular virtualdub doesnt.....
  9. Member Safesurfer's Avatar
    Mar 2004
    Yes, it works with any variety of VirtualDub.
  10. Member geohei's Avatar
    May 2002
    Luxembourg
    /Mats
    Yes right ... now it works.
    Thanks a lot!
