I'm trying to install video codecs (XVID), and I get "Unable to register DLL/OCX". I've had various versions of the klmcodec packacges installed for a number of years, and now I'm getting the message also when I try to install any video codec. Is something corrupt in the registry and is there a fix for it?
Thanks.![]()
Codec packages = bad news. For this very reason. often they clash, if not internally then with other things you may need to install later.
I would uninstall the codec pack(s) completely, then use Codec Sniper to cleanup what's left. Then download the latest (2.52) beta of G-Spot and use this to determine what codecs you do need, and install just the official versions of these.Read my blog here.
I tried and it didn't work. Did a lot of research on the web but didn't find anything that corrected my problem. End result? - You guessed it - formatted my hard drive and reinstalled Windows. Bummer.
Keep getting libfftw3f-3.dll could not be loaded error.
By Nagashi in forum Video ConversionReplies: 4Last Post: 13th Jul 2016, 15:16 -
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Virtualdub Error Message - Failed to load FFmpeg.dll
By SOSmkII in forum Video ConversionReplies: 5Last Post: 6th Feb 2012, 07:14 -
enc_aacplus.dll error while using AutoMKV
By nx01rules in forum DVD RippingReplies: 3Last Post: 15th Oct 2009, 04:24 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
