    Sep 2001
    Tasmania - Australia
    Guys, I have a standalone sony digital amp(STR-DE675) been running my hi-fi vcr and sony DVD player through it, getting the best from it i.e. digital dolby and DTS depending on the disk, and I made the fatal mistake of lending to friend. He was unable to get it to play any of the above features when he hooked his phillips DVD up to it
    only played in normal pro logic(his DVD supported all above features, and tried everything)). When I plugged my equipment back into I have the same problem and it wont play any dolby digital(sound effects) from the amp anymore
    , even though dolby digital displays in the DVD display?I've tried clearing the memory via the instruction manual: no good!
    I am aware that there is a techie code that can reset all parameters back to fac. defaults, does anyone know what it may be or a sight similar to VCDhelp that could help.
    Any help would be greatly appreciated and thanks in advance
    Cheers
    Dave
    Welcome my son, welcome to the machine.
    Feb 2001
    51`N 5'W #linux & #vcdhelp @ DALnet
    Ahhh, the legendary codes of Sony crop up once again.
    My Sony TV is stuck in 16:9 format, good, but it is a 4:3 TV: The picture is only psuedo widescreen so I am stuck with a squashed picture.
    Now, it has been fixed once before by a Sony engineer when under guarantee, but now it is out of guarantee, the SOB's want some ridiculous amount of money so a guy can come round and put in a few numbers into the remote to reset the stupid thing. F*** that: I just live with it.
    If your amp is new, take it back to the shop if it is under guarantee. Other than that, good luck. The only other reason is if your friend messed with the settings.
    Trying to get Sony Codes is like trying to extract chickens teeth.
    <font size=-1>[ This Message was edited by: d4n13l on 2001-12-29 13:19:06 ]</font>
  3. Member zzyzzx's Avatar
    Baltimore, MD USA
    Yet another reason not to buy a Sony.
    Sep 2001
    zzyzzx, you may bag sony but fine by me. d4n12l I found a site with all the codes but no real instructions to match so hesatent to play around with the bastard. Its under warranty so its heading back home to be soughted, thanks for the reply anyway!!
    Dave
    Feb 2001
    You dont have the link for that site do you? I might try to reset my TV if I had a lead to go on.
    Sep 2001
    d4n13l try this site: http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
    Goodluck
    Dave
    Feb 2001
    Gracias
