Which brand of Dual(or Double) layer media is the best to get? I've seen no 'Made in Japan' +/- DL media, so I was wondering which would be most reliable considering the options available?
Results 1 to 10 of 10
The general consensus among people in the know are that the ONLY consistently reliable DL media is Verbatim's.Originally Posted by SilverBlade
And, of the Verbatim DL media available, it is much better to go with the + type. -
What is the difference between DVD+R DL and DVD-R DL. The + variety seems to be ubiquitous, but I have always used Ritek DVD-R for single layer discs and they have been outstanding.
No one ever seems to be able to give a straight answer when I ask this either. Especially the morons at Comp USA. -
There's this explanation on lordsmurf's site that is fairly good:
http://www.digitalfaq.com/media/dvdformats.htm -
The short answer is that the +R DL recordable DVD media is more compatible and more flexible (i.e., -R DL media has a fixed layer break while the +R DL media has one that can be calculated and changed.)Originally Posted by motherwell
IMHO, the -R DL camp really screwed up when it came to their DL version of recordable DVD.
For single layer media, -R is great (but then again, so is +R in 01/2006).Originally Posted by motherwell -
DVD+R DL works. It's also easier to find and cheaper. But ONLY use Verbatim (MKM) discs. That is enough to know, to be quit honest, for most people.
DVD-R DL suffers much the same as DVD+R and DVD+RW suffered. It's more expensive, not as easy to find, and there are issues with how well the discs work for DVD-Video burning. Of course, as DVD+R has shown, that is always subject to change.Want my help? Ask here! (not via PM!)
Thanks for the info. I am glad they have made all of this user friendly.
I just wanted to add that I bought a 3 pack of DVD-R DL so I could experiment with it. My Philips DVP-642 has big problems with the discs. It will play them, but only with errors. I have a post about this in the DVD Players section of the forum. From now on I will only use DVD+R DL and I won't buy any CD or DVD media at all unless it is Verbatim.
My first experiences of DL burning were with Verbatim DVD+R just over a year ago when they were still £9.99 per disc. I only bought 3 discs (due to the price) but all 3 failed to write to the 2nd layer. Maybe my fault, maybe not.
I have recently begun using DL's again as the price is coming down and so far, so good as of the 20 discs purchased, all 20 have gone to plan with flawless playback (if i knew how to run a speed test etc, i would
The discs i'm using (Ridisc) work out at £1.50 each. Here's a link if anyone's interested:
http://www.diskdepot.co.uk/acatalog/DVD_DL_Dual_Layer.html#aDVP_2d046
Ha-do-KenAttack me if you dare...I will crush you.
Looking for some cheap Dual Layer Bluray media (BD-R DL) ..
By ahmadka in forum MediaReplies: 0Last Post: 26th Mar 2011, 22:07 -
DVD dual layer media ~ thickness/price
By Micker_C in forum Newbie / General discussionsReplies: 10Last Post: 5th Nov 2008, 23:23 -
Double-Sided, Dual-Layer DVD media?
By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 15:03 -
Whats the status lately on dual-Layer media?
By Super Warrior in forum MediaReplies: 22Last Post: 1st Feb 2008, 21:21 -
Dual Layer hub printable media??
By garstan in forum MediaReplies: 4Last Post: 21st Oct 2007, 14:50
