I have an ATI HDTV Wonder card that i've captured tv with using indows Movie macker, but i hate that software so I gto adobe Premiere Elements. The only problem is that premiere doesnt regonize the capture card, or i dont know how to set it up. It always says the device is off-line. So can elements do this tyoe of capture or is it firewire or usb only?
I'm trying to capture video from an analog source and have suscessfuly done it using the ATI card with windows movie maker. Bu i dont want to use that software. So is there away to ger elements to regonize this card?
Thanks for any help and advice.
Far from expert with prem, all I can tell you is most capture apps or applets bundled or built-into NLEs nowdays are looking for DV video transfer via firewire. You might want to search the forum sections a bit and see what others are using with HD cards, &/or see if the new MMC works with your handware.
Adobe Premiere Elements
By willmington in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2011, 04:14 -
Video lags, drags, stutters when previewing in Adobe Premiere Elements...
By Captain Satellite in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2010, 09:13 -
Looking for alternative to Adobe Premiere Elements...
By Heyjoojoo in forum Authoring (DVD)Replies: 4Last Post: 27th Jan 2010, 14:34 -
Adobe Premiere Elements is cutting off the end of video when exporting
By robvs in forum EditingReplies: 0Last Post: 19th May 2009, 18:47 -
Adobe Premiere Elements 4
By pepegot1 in forum EditingReplies: 12Last Post: 28th Sep 2007, 11:59
