OK - here's one for all the tech gurus (and please correct me if I'm totally wrong about anything):
When burning a DVD/CD, does the intensity of the laser increase as the burning speed increases? I'm assuming that the "burn intensity" would have to increase when burning at 8X speed as opposed to 4x speed, simply because the disc is spinning faster- is this correct?
If that is the case, would always burning at max speed actually decrease the lifespan of the laser, since it would be constantly operating at "max burn intensity"; in other words, would burning at say, 2x or 4x speed increase the operational life of the burner?
Just curious.....
Results 1 to 1 of 1
You can't fool me, I'm a moron!
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Burning speeds
By Rogert in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2008, 07:28 -
technical question on center ch. of Dolby Digital
By dondeaida in forum AudioReplies: 5Last Post: 19th Aug 2007, 08:11 -
Burning at lower speeds lengthens the life or your burner?
By LittleQueenie in forum MediaReplies: 10Last Post: 25th Jun 2007, 18:40 -
Burning speeds and DVD Decrypter...
By Nilfennasion in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2007, 04:32
