I tried to convert the 16:9 DVD VOB file(creaded by Sony DVD Camcoder) to mpeg2 file (no re-encoding), the problem is all the software I tried change the 16:9 AR to 4:3 in the mpeg2 file. When I open the mpeg2 files under ulead videostudio9 to edit, I can not get the right AR. Please advise how to solve this issue. Thanks
you set it to 16:9 when you export to dvd.
if you are going to join with other clips that are 4:3 you can add borders to get correct ar. -
Thank you for your comments. There are must be a way to specify the correct AR in mpeg file so that the mpeg file can be played correctly on computer. The Sony boundled software can convert the miniDVD to 16:9 mpeg correctly. Unfortunately it can not do the convertion from the DVD folder on hard drive.Originally Posted by Baldrick
Great! This solved my problem. Thank you gshelley61. I knew I can always get the right anser from you smart guys.Originally Posted by gshelley61
I tried different solutions and found DVDpatcher is the best one. It does not re-stream the file. It just patches the header of the MPEG file from 4:3 to 16:9.
Ripped VOB #1 wrong aspect ratio, all others ok!
By silver007 in forum DVD RippingReplies: 8Last Post: 6th Jun 2009, 12:01 -
vob to wmv crop/aspect ratio???
By eao1 in forum Newbie / General discussionsReplies: 6Last Post: 29th Mar 2009, 15:00 -
Some VOB's not displaying the correct aspect ratio
By Browncoat in forum Media Center PC / MediaCentersReplies: 26Last Post: 20th Mar 2009, 03:57 -
VOB Aspect Ratio
By Lt. Dang in forum Newbie / General discussionsReplies: 7Last Post: 1st Feb 2009, 19:17 -
.vob to .dv, aspect ratio problems
By Groove_Holmes in forum ffmpegX general discussionReplies: 2Last Post: 23rd May 2008, 21:34
