Hi everyone at videohelp!
Iam am working on a dvd to my my that I have created. I have made some menus and now Im working with the main menu. I got inspired from The Monty Python and the holy grail dvd. They got a button that changes the audio in the menu its called "har of hearing" where a voice scream out the different sellections. Im useing Adobe Encore 1.5 and I wonder if anyone of you got a clue about what to do? I have tried creating a new timeline where I inserted 2 audio trecks. Then I linked the timeline to the menu and created a button which I hought I just linked to the main menu and choose audio 2 ut i doesent seem to work =/
So I need som help from you, the more experienced once =)
Do you have the movie ? If so, try opening it in DVD Shrink to examine the structure of the menu. They may have used multiple audio, or they may have used a substitute menu (repeated same menu with different audio)
Read my blog here.
Well it seems like they are only using an animated background, I think. They are probably using chapters to change audio e.g. Ive tried to make a new menu with a different sound in it. It works pretty well because I dont got any movements in the main menu. Iam gonna try and se how well it works with motions in the background, maybe I have to make a transition or solve the problem like they have done. Thanks for the help by the way guns1inger =)
Can I create my own custom Button in TMPGEnc Authoring Workshop 4?
By JackyWang in forum Authoring (DVD)Replies: 4Last Post: 31st Aug 2016, 22:14 -
How To Create A functional button and replace the DVD menu using free tools
By escarlate in forum User guidesReplies: 4Last Post: 31st May 2011, 01:44 -
Change and delete some button in motion Menu?
By p_samimi in forum Authoring (DVD)Replies: 4Last Post: 7th Sep 2009, 15:52 -
How can I turn on a audio by Ifedit? Add button to orginal menu
By schtroumpfs in forum Authoring (DVD)Replies: 4Last Post: 11th May 2009, 09:20 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
