Hello, whenever I convert movie's into a VCD recordable formate with TMPGEnc and rip the sound, and do all that good stuff just to make a VCD, my windows media player on the internet to stream videos gets messed up. I have WMP 10, and after i burn a VCD, and go to a site and stream any video it would be using WMP 6.0 which isn't compable with alot of sites nowadays but when i open up WMP its still WMP 10. Can anyone help me figure out whats going on, because it really annoying after burning a VCD i have to set up WMP 10 agian and restart my comp.
thank you.
WMP6 or Media Player Classic (which looks a lot like the old WMP) ? Somehow your associations are getting screwed up. I would suggest that one of the processes you use calls MPC, which then changes the associations. I would be surprised if it didn't propmpt you though, so I suspect you say yes to something without reading the fine print.
Read my blog here.
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 07:28 -
WD Live Media Player vs Roku HD Media Player
By marionr26 in forum Media Center PC / MediaCentersReplies: 1Last Post: 9th Dec 2010, 07:48 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49 -
Media Player Classic and Windows Media Player 9.0
By siluet in forum Software PlayingReplies: 0Last Post: 26th Dec 2007, 10:01 -
how do I flip an AVI video in windows media player or media player classi
By mdavenport in forum Newbie / General discussionsReplies: 2Last Post: 5th Jul 2007, 23:18
