I've been trying to do 1080i to 480i dvd conversions from hdtv. It looks ok but I did test one out on a hdtv at my sister's house and it was really jerky movement. But it looks ok as far as I can tell on a regular tv.
What I've been using is tmpgenc and not doing any deinterlacing or pulldown or the like. I just tell it to go from interlace to interlace. But my question is HOW DO YOU DETERMINE THE FIELD ORDER?
Is there a surefire way to always get the correct field order for the conversion??? 720p is so easy to convert because you just tell tmpgenc its a progressive source and thats it. But with interlace I'm still not 100% sure.
What programs can read the .ts file and tell me what the field order is to ensure a proper 1080i to 480i encoding??? Because I'd like to be able to make a dvd from a 1080i source that looks good on a hdtv AND a standard (I only have a standard tv myself). I don't want to have to deinterlace it if I have to because I imagine that will add a CONSIDERABLE amount of processing time - I'd like to avoid that if possible.
Thanks again for all the great help. My 720p to 480p discs look GREAT
Hi-
Most TV shows these days are also shot on film, have a native framerate of 23.976fps, and could also benefit from IVTC. Good luck.
Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080i
By adrien23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 12th Nov 2010, 05:37 -
1080i to 480i
By Anonymous344 in forum Video ConversionReplies: 62Last Post: 7th Aug 2010, 09:15 -
1080i to Standard DVD
By noisymonk in forum EditingReplies: 4Last Post: 3rd Jun 2010, 17:03 -
Using AVCHD (1080i) instead of regular AVI-DV (480i) MINI-DV - argh!
By eddie24 in forum Video ConversionReplies: 4Last Post: 6th Oct 2008, 19:32 -
Is it playing 480i or 1080i???
By elmertborts in forum DVD & Blu-ray PlayersReplies: 3Last Post: 22nd Jan 2008, 13:25
