Ok,
I have a complicated question that i'm hoping to find a simple solution to.
I want to create a fairly large quantity of dvd using either (or both) studio 10 or premier pro. The catch is that it is a 45 min video, with a unique clip added to the end of the DVD. It takes to long to mass produce having to render the entire 50 minutes.
Is there a way only render the last 5 minutes (new clip) if the first 45 minutes has already been rendered?
Is there a way to join already rendered parts? I have seen some posts on this site about possibly changing the vob_xx_y files, but have not had luck. I may have just not understood the post.
If anybody can lend me a helping hand - I would greatly appreciate it.
I hope I put this in the right forum- If not-sorry
I'm Ben in Colorado -- Go broncos
All I have to author is Pinnecle studio 10 and Premier Pro -
Is there anyway to use what I already have? -
Premiere Pro doesn't author. I don't know pinnacle.
The advantage of the TDA approach is you just render the 45 minutes to ne clip, make as many 5 minute endings as you need, and roll them as required.Read my blog here.
Premiere Pro 2.0 does have basic DVD authoring capabilities.Originally Posted by guns1inger
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 14:50 -
Questions about using Adobe Premier Pro
By Graemey in forum Newbie / General discussionsReplies: 2Last Post: 21st Mar 2010, 07:02 -
not enough disk space - Adobe premier Pro 2.0
By Reggie6966 in forum Newbie / General discussionsReplies: 11Last Post: 8th Nov 2009, 04:07 -
Adobe Premier Pro to dvd
By tat2loo in forum Newbie / General discussionsReplies: 7Last Post: 29th Apr 2008, 13:57 -
Adobe Premier Pro - Mpg - Skipping.
By primalmedia in forum EditingReplies: 1Last Post: 7th Nov 2007, 11:35
