I have a PSP-MP4 video that is only able to be viewed in 16:9 mode. The problem is, the source material was obviously 4:3, so the image is stretched.
Is there a program that i could use to fix this problem without re-encoding? I know how to do this with MPEG-2, but I've never had to it with MP4...
asdf
Probably not. Generally, PC based files have a 1:1 pixel aspect ratio and no DAR (although it is possible to store one, nothing really uses it). The main exception to this is DV-AVI, where some editors will observe the 16:9 flag if set.
I suspect you will have to reseize the video to the correct aspect ratio and rencode. This will let the playback device display it correctly and add whaever bars are necessary.Read my blog here.
Well, this isnt really a PC based file, as its formatted for playback on my PSP. Normally, while playing the file, i can change the view mode, which involves changing between 1:1, 16:9 and 4:3 - zoomed, or cropped.
The problem is, with this video, it is locked so that the aspect ratio can not be changed to 4:3 because it was incorrectly given the 16:9 flag. I would like to remove it and change it to either 4:3 or 1:1.asdf -
Hopefully this will help
https://forum.videohelp.com/viewtopic.php?t=285971&highlight=mp4+aspect+ratio
It refers to Mac software in this instance, but I suspect the underlying issue is the same.Read my blog here.
mp4box/yamb from recollection can change the PAR. Sounds like maybe it wouldn't make any difference though.
Convert VOB file to MP4 (PSP)
By HunterD in forum Video ConversionReplies: 4Last Post: 5th Mar 2010, 02:39 -
PSP(MP4) Video Conversion...
By Nizomi in forum Newbie / General discussionsReplies: 7Last Post: 11th Oct 2008, 03:53 -
mp4/psp sounds problems
By Nick1982 in forum Newbie / General discussionsReplies: 1Last Post: 21st Jul 2007, 15:22 -
MP4 (PSP) EDITOR help
By efiste2 in forum EditingReplies: 6Last Post: 29th Jun 2007, 13:54 -
psp and mp4's
By zinc in forum Portable VideoReplies: 4Last Post: 19th Jun 2007, 13:50
