  1. Hello all my name is Brian. My problem is that i want to capture video with final cut pro then export to DVD (I mainly use iDVD just for simplicity) When i go to watch my final product back it is one big clump of video.... What i would like to do is be able to have an index of the avaible videos cut into lets say 48 pieces. Almost exactly like they have in conventional DVD movies, you have a Play movie and a scean selection. I don't want to go in and make chapters one by one i would rather have a way i can make a default markers for 48? Please someone help me....
    Dec 2003
    Eugene, Oregon
    Just in case you don't get the info you need here, there are two excellent sites for FCP info. One is Ken Stone's site at http://kenstone.net/fcp_homepage/fcp_homepage_index.html and the other is the Final Cut forum at http://discussions.apple.com/category.jspa?categoryID=123
  3. thanks, i am just so frazled, i think i concocted a way to do it but i will look into the sites, thank you very much!
    Apr 2004
    Earth
    if you add chapter marks to your timeline in fcp, then export through compressor, they will be available as chapters when you import the asset into dvd studio pro. position the playhead on the timeline where you want the chapter, press M to add a marker, then press M again to open the marker menu, choose CHAPTER MARKER, click ok. repeat as necessary...
  5. Member terryj's Avatar
    N35°25.24068, W097°34.204
    WHAT?
    SoundFX, you only need to press M once, not twice?
    Repeatedly pressing M will create Chapter Markers
    in the same spot, and eventually the Mac will
    beep at you for it.
    I just checked this in DVDSP3, and sure enough,
    you press M twice, you get TWO chapter Markers
    in the same spot, and the Mac beeps "error".
    The Inspector palette automatically changes to the Marker Palette,
    and you can name the Chapter Marker from there
    as well as set its end jump in the timeline, once you've
    pressed M once on the keyboard, when playing the video in the timeline.
    Perhaps your setting/config is off? I'm using the
    Advanced Config in DVDSP3....
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  6. ^terry, he's talking about adding the markers in FCP, and he is correct. In FCP pressing "M" once makes a marker, and then you press "M" again to define the marker (chapter, Compressor, etc.)
    Friends don't let friends use Windows!
    Elisha Cuthbert is so a total schorchcake!!
  7. yea i know about the m twice, i just wanted o know if there was a way to make un-defined ones. I figgured out my own way to do it though, hanks for all the help
  8. Member terryj's Avatar
    aaah, after re-reading it I get his drift.
    Perhaps this is why I do this in DVDSP,
    because it is more intuitive and you only have to do it
    once as part of the mastering procedure,
    in the build of the DVD....makes more sense to me, then
    you don't also have to remember to set the "import Chapter Markers"
    flag in Compressor so that DVDSP can pick them up....
    Urban Mac User
