Hi all,
I noticed when I watch a backed up dvd the sound is very low. I am currently using XP, nero and dvd decrypter. Does anyone know how to fix this problem? I have searched this site and asked friends a few questions but with no luck.
Results 1 to 10 of 10
if you are making a backup of the dvd and havent re-encoded anything the audio/video should be the same as the source. what is the exact process you are using?
Sound is low on dvd player haven't tried the PC.
The exeact process I'm using is to use dvd decrypter which is saved to HD. I then use nero to burn. I have not played with any settings in decrypter or nero. Is this correct or do you need more info?
cheers -
If you don't need to reduce the size of the disk, use DVD Decrypter in ISO mode (Mode, ISO->Read) to copy the disc, then again to burn the new copy (Mode, ISO->Write).
If you are using Nero to reduce the size of the disc it *might* be screwing with it in some way, but again, it depends what you are doing.Read my blog here.
I made a back up of a dvd at friends house and did it the exact same way with exact software ie. xp, nero and dvd decyrptor and the sound was perfect. Could it be the way my pc is set up?
cheers -
I'm new to this and my friend told me that is the way he does it. Is there a easier or better way?Originally Posted by guns1inger
cheers -
I use this process DVD Decrypter ISO READ, DVD Shrink and burn with NERO 7 I have only had a problem with sound once which was due to how my stereo was set up there was no problem with the DVD. Try to play it on another player.
Read this before wasting too many DVD-Rs http://forum.digital-digest.com/showthread.php?t=49051 -
Also when using Nero access fom all programs list NOT quick start, and be sure to choose DVD Video.
Low Sound Output After Adding .ssa to .avi
By edlimym in forum SubtitleReplies: 4Last Post: 12th May 2010, 08:02 -
Uncompressed AVI plays back in low quality with WMP12 & Pinnacle Studio 14
By textmagic in forum Software PlayingReplies: 2Last Post: 2nd Apr 2010, 05:25 -
Low sound in rear speakers.
By madman1987 in forum AudioReplies: 5Last Post: 24th Nov 2008, 13:44 -
low sound after burning to dvd
By ymurf in forum Newbie / General discussionsReplies: 3Last Post: 3rd Feb 2008, 15:59 -
DVD sound is terrible played back on stand alone players
By nikoz in forum Capturing and VCRReplies: 0Last Post: 12th May 2007, 19:13
