I'm trying to capture video at 320x240 resolution, 30 frames per second, and
am dropping about 70% of the frames. Something is very wrong. I turned off
audio capture, so it's not an audio sync problem. What else could it be?
My system is: Athlon 1400, 512 mbytes memory, 7200 RPM disk, Windows 2000.
Video capture card is an Osprey 220. Any ideas at what I should look at
find/fix the problem?
Does this happen all the time or does it start dropping frames after like 30 minutes ?
I've been battling with exactly the same problem for months now and tonight decided to try and solve it.
Two things fixed it for me. I have the WinTV card, so I ran HWCLEAR to eliminate all traces of the WinTV drivers from my machine. I then downloaded the latest driver.
I also found that my video card driver was out of date so I downloaded the latest update for Win2000 for that. I also switched on the option to enable bus mastering on the video card.
Finally, I installed Direct X 8.1
Now after trying to capture again, I get about 1 frame dropped every 450 (less than 0.004%) which is fine by me, I'm running a 1GHz Athlon with 512Mb RAM. CPU usage during capture is now down to about 25% from 95%.
I'd say look at your video card driver and possibly update that.
Cheers
Graham
High Quality Capturing with Little Frame Loss in VirtualDub
By monsoon01 in forum User guidesReplies: 65Last Post: 18th May 2013, 23:33 -
Subtitle massive shifting
By zibizibi in forum SubtitleReplies: 5Last Post: 12th Jul 2011, 07:32 -
Massive conversion operation
By NickPapageorgio in forum Video ConversionReplies: 1Last Post: 28th Jun 2011, 15:36 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 17:26 -
Massive Video Project
By BlazingSpeed in forum Newbie / General discussionsReplies: 11Last Post: 6th Jul 2010, 22:33
