    Jun 2005
    canada
    I've not come across an rmvb file before and I'm wondering if SD2 will load and convert this type of file as it does with avi files?
  2. Doesn't look likely, ffmpeg kicks an error when I load an rmvb asset.
  3. Is this format supported please chrissyboy ??
  4. He is offline for a few days on business.
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    What is the file? Never heard of rmvb...
  6. It Real Player Variable Bitrate... produced by and played back using RealPlayer
  7. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Then at this time no (as with wmv etc).. All the samples (of wmv) i have looked at are so inconsistant and so quality/expected results are not what they should be.
    Jun 2005
    canada
    For member info, I found DVDSanta converts rmvb files directly to vob's. Takes a while but works great.
