Hi,
What software can I use that will convert MPEG2 file to VOB format. Free, shareware or comercial. Thanks
any dvd authoring toooooooool, https://www.videohelp.com/tools?s=2#2
Why are you converting your MPEG to VOB. Are you authoring a DVD. If yes, then as already suggested by Baldrick, any authoring tool will automatically convert your MPEG to VOB.
If you want to view you MPEG on your PC you might just leave it as MPEG-2.When I was born I was so shocked that I could'nt speak for 18 months.
VOB into one(!) mpeg2 file
By mitchellgoosen in forum ffmpegX general discussionReplies: 2Last Post: 13th May 2009, 10:19 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 02:12 -
How is done the sync between audio and video in a MPEG2-VOB file stream
By rmanal in forum EditingReplies: 0Last Post: 22nd Aug 2007, 10:33 -
Video Stutter / Skip when coverting from DVD to VOB / MPEG2 file
By afs_nj in forum MacReplies: 2Last Post: 13th Jul 2007, 16:39
