Good Morning,
I have audio / video synchronize problem - Static Delay - for my AVI file,,,
How to fix this problem???
Can I get some guidelines,,,,,,,,,
Thanks in advance,,
Results 1 to 16 of 16
Virtualdubmod, streams, select stream, right-click, interleaving, add delay (can be + or -). Save out again with direct stream copy.
(Note: doing a heavy 3D render at the moment, so can't open Vdub to confirm steps. They will be close, but perhaps not 100%)Read my blog here.
Thanks for u r input - Guns - letme try - I will be back with result,,,,,Originally Posted by guns1inger
Hai Guns, I did the changes.Originally Posted by guns1inger
But one thing is not clear, we have to go " file save as" or just go for "Save" the same file??
Pls can u give some idea!!
Thanks in Advance -
Today I tried as u said,, In Virtualdubmod, select stream, right-click, interleaving, add delay time than I saved the file "Save As" different location and diff name,, 700 mb file occupy more than 12 gb,,,Originally Posted by guns1inger
U have any Idea?? why single file take this much space,,,
If u don't mind can u check the " Step " what I did is " Right?? or Wrong??"
Guide me pls,, -
Make sure you set video to direct stream copy under the video menu or it will re-encode. The default is uncompressed, hence the size. It was the final step in my (very) brief instructions.
I needed more detail to tell you where this setting was.Save out again with direct stream copy.Read my blog here.
Thanks for u r info,,,,,,Let me try again as per u r direction,,,, I will be back to u,,,,,, after one hr......Originally Posted by guns1inger
I gone throu,,,,,,,,,, I made 06 copies to get the job,,,,,,,,,, Still on going,,,,,,,,,, 50 % is getting ok,,,,,, Need more copy to fix the time delay,,,,,,
I will come back with result,,,
Thanks for u r info and help,,, bye and god nite........... -
You don't need to save every time to check the result of your adjustment. Just play the file in the main screen, adjust as necessary until you get it right, then save a final copy.Originally Posted by thankam
"Art is making something out of nothing and selling it." - Frank Zappa -
Hai Zippy,Originally Posted by ZippyP.
More info, The movie is playing very nice in my PC, But when I tried my " Stand Alone Player' the problems is there,,,, So I am making some adjustment & copy for the " A/V " Test. -
Hai Guns / ZippyP,
Still I have the audio syn problem,,
This file is working nice in PC,,,, But "Stand Alone" is having this A/V Syn problems.
Again I open the avi file wtih Virtualdubmod, I got the msg as below, ( This msgs is coming since begining )
How to correct this???
Thanks in advance,,, -
1. Streams -> Streams List. Right-click and choose Full Processing Mode. Highlight the audio stream, right-click Compression. Set it to either uncompressed wav, if you intend to use it later for authoring, or MP3 CBR. Save Wav.
2. Once this is done, while still in the stream list, click Add and browse to the new audio file. Click OK. Highlight it in the list, and move it to the top using the Move Up button.
3. Highlight the original audio track, and click on Disable.
4. Right-click and set to Direct Stream Copy. Also make sure Video is Direct Stream Copy
5. File->Save as an give it a new name.
Before step 5, make sure you have sync by playing it back.Read my blog here.
Thanks a lot Guns - for u r guide lines,,,
Let me try,,,
Jobs are on going,,,,, I will be back with result,,,,, -
Hai Guns
I got it fixed that audio delay,,,,
Thank you very much,,,
Sorry for the delay msgs,,,,
Synchronize Audio and Video from Different Sources
By Bruno AUgusto in forum AudioReplies: 2Last Post: 22nd Nov 2011, 19:27 -
Adding audio (wav) to video (avi) (want to delay start of audio)
By Lanton in forum Newbie / General discussionsReplies: 2Last Post: 12th Apr 2010, 13:50 -
Can't synchronize audio/video with Vegas
By dexter30 in forum EditingReplies: 1Last Post: 2nd Oct 2009, 17:05 -
video/audio delay
By cyber69 in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2008, 15:45 -
Synchronize audio and video with different framerates
By dexter30 in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2008, 15:53
