I have a combo with several items. With the selection of each individual item, a different action would be performed. Is there a way to code this simply rather than using 19 separate IF/THEN statements?
Currently it would look something like this:
If cboComboBox.Text = X Then
A=B
This is just an example. But imagine that about 20 times. It gets a little long.
I haven't coded in VB in a long time (probably since VB3) and have only recently dabbled with C#, so maybe this wont help, but what about a case type statement. Not a lot less work, but probably easier in the long run. Don't know the exact syntax though.
Read my blog here.
Case syntax would be something like the following (in the cboComboBox_Change() sub) :
... or alternatively run it off the Index property (which IIRC is available in the _change() event).Code:Select Case cboComboBox.Text Case "X" A=B Case "Y" C=D Case Else E=F End Select
... or alternatively you *might* be able to use an array.If in doubt, Google it.
XMP – Metadata related question
By pavinm in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2010, 14:53 -
A question related to sub files and resized avi with AGK
By loninappleton in forum Newbie / General discussionsReplies: 7Last Post: 19th Jul 2009, 22:35 -
DTV converter box, screen size-related question
By Ai Haibara in forum DVB / IPTVReplies: 6Last Post: 22nd Nov 2008, 18:18 -
Fraps and Ventrilo Related Question
By combatsimulation in forum AudioReplies: 0Last Post: 23rd Feb 2008, 19:05 -
You Tube related question
By bja5150 in forum ComputerReplies: 2Last Post: 24th Dec 2007, 10:39
