I have about 230 rm. files and i want to put them on my ipod so i can see them. I have tried converting these movies to ipod format, and i have found a way to by 1st converting it to AVI Divx using the mencoder, and then to quicktime .mov format. I have tried, but i cannot go directly to .mov format. Then i drag the file to iTunes and use the new convert selection to iPod tab in the tools bar. This works, but when i do the size increases from 35 MB to about 135MB. I was just wondering if there is another way to get RMs on an iPod without makin the file so big, like maybe using a 3rd party converter instead of iTunes, like iSquint, or something in the ffmpegx part of the conversion
Results 1 to 13 of 13
You should convert first to AVI DivX with mencoder, and then to iPod by using the iPod presets.
The iPod preset assumes that the source video is already at the same-or-greater resolution and bitrate of the iPod format. What's probably happening is that your video is getting scaled UP and the birate is being set higher than the original video.
Take note of the video bitrate, audio bitrate, video size and audio channels. Then modify the "iPod Preset" settings to closely match these.
If you don't understand any of that, then I would suggest you leave well enough alone and accept the increased file size.- macr0t0r
When did email start feeling like work?
i changed the format using the ipod h.264, and the file was only 28.6 mb after i adjusted some of the things like bit rate, but the file was able to be played by any media player, even vlc. the file ended in .264, is there anything i can do to fix this
The .264 is a temporary file, it is going to be erased automatically at the end of the encoding and replaced by a .mp4 file, unless there is an error interrupting the process (in that case, click the blue "i" button in the Progress window and copy/paste me the error by sending me an email to major4@mac.com).
Ripbot264 iPod format will play on iTunes but won't sync to iPod/iTouch?
By Riley007 in forum Blu-ray RippingReplies: 2Last Post: 31st Dec 2010, 01:04 -
File Converted by Handbrake (0.9.3) Using iPod Preset Won't Play on iPod
By GrayStrickland in forum Video ConversionReplies: 0Last Post: 8th Mar 2009, 21:56 -
iPod dock picking up interference from iPod
By snadge in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2009, 10:37 -
any Ipod experts? way to restore lost music on Ipod
By scustalow in forum Portable VideoReplies: 2Last Post: 9th Jul 2008, 01:56 -
IPod nano with video and IPod touch
By SingSing in forum Latest Video NewsReplies: 0Last Post: 6th Sep 2007, 11:11
