I'm looking for an hardware DivX capturing device.
Is it good for you this one?
http://www.hb-direct.com/EN/P_51_1.html
Thanks :P
Results 1 to 11 of 11
Look here:
http://www.thenoisereport.com/modules.php?name=Content&pa=showpage&pid=14&page=6
WIS Technologies GO7007SB IS a divx Video Encoder -
Here there is a fully and detailed review with some video samples:
http://www.cdrinfo.com/Sections/Reviews/Print.aspx?ArticleId=10154
It looks very good!
My error I mean't not ture full blowing hardware capturing device you should beware that the audio is soft encode unless you using PCM mode which in case that mode dosen't alway keep sync and problem is that the WIS GO7007SB dosen't natively supports encoding audio into MP2 nor MP3.
I have scean other capture card build this vary same way like that one and it alway seem to have the very same major problem. -
Yes, It does hardware divx capturing of video stream only, not audio (done via software)...yes I watched comments of this capture device: https://www.videohelp.com/capturecards.php?CaptureCardRead=391...audio sync sometimes get off...
Try the InstantDVD+MP3 from ADSTech (www.adstech.com). New product that was unveiled at the CES 2006 a couple weeks ago.Originally Posted by alebertaz
I wonder what under hood of that InstantDVD+MP3 and if really dose 2-channel AC-3 in Hardware Encoding
The MPEG 2 and 4 videos are all drop field deinterlaced. Ugly. And the MPEG 4 videos aren't much smaller (MB/min) than the MPEG 2 equivalents.Originally Posted by alebertaz
On closer examination the HQ MPEG 4 video looked better (less macroblocking) than the HQ MPEG 2 video. At GQ the situation was reversed. -
It seems really very good but we should wait for a review in order to avoid ugly surprises (such as macroblocking, audio sync, driver problems etc...)Originally Posted by SHS
Today only, Pinnacle hardware DivX capture box.
By olyteddy in forum Capturing and VCRReplies: 0Last Post: 7th Nov 2008, 10:56 -
Capture Cards with hardware compression to Xvid/Divx?
By quantass in forum Capturing and VCRReplies: 7Last Post: 31st Aug 2008, 20:50 -
Xilisoft DVD to Divx Convertor
By didikai in forum Newbie / General discussionsReplies: 3Last Post: 7th Feb 2008, 15:23 -
Cropping in Divx Convertor or Divx Author???
By rahul.never2far in forum EditingReplies: 9Last Post: 25th Sep 2007, 11:28 -
DIVX convertor / resolution
By surfer in forum Video ConversionReplies: 2Last Post: 10th Jun 2007, 04:56
