how much of a difference in quality to the human eye does 2 pass VBR have over 1 pass?
with a 1 pass vbr mainconcept shows the size of the output file before encoding.
Not enough to warrant double encoding time IMO.
/Mats -
It really depends on the quality/content of the source. If you have high action scenes balanced by low action scenes and the source is clean, 2 pass VBR can give excellent results while increasing the amount you can fit on a disk. If the source is noisy or all action, then 2 pass VBR is probably not going to show much difference. In order for VBR to be effective, (not CQ) the encoder needs to be able to "borrow" bits from areas that compress well and use them in areas that need the extra bitrate. CQ is different because it's not trying to meet a specific target size.
Buy My Books
Difference Between 1 pass & 2 pass encoding
By iqbal88 in forum Video ConversionReplies: 28Last Post: 29th Oct 2021, 06:19 -
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 22:11 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 07:59 -
1 pass and 2 pass bit rate query
By socrates in forum Blu-ray RippingReplies: 1Last Post: 26th Nov 2010, 16:18 -
Retrospectively check if One Pass or Two Pass Encoding was used?
By BenjaminBS in forum Video ConversionReplies: 4Last Post: 26th Nov 2009, 06:46
