There's a compatibility issue (aka bug) when DivX6 encoder is used from VirtualDub or VirtualDubMod. Short description (so you can tryout by yourself):
1.From VirtualDub select DivX 6.1.1 Codec (=latest version) for compression.
2.Configure the Codec by selecting Video tab.
3.Enter 32 for crop left and 32 for crop right (other settings doesn't matter).
4.If VirtualDub didn't crash till now, confirm with OK.
5.If VirtualDub didn't crash till now, try to convert your source file.
6.VirtualDub should crash till now, showing some kernel32 error message.
This, of course, doesn't happen when DivX5 codec is used, so it could be DivX6 bug...
Now exit Configure codec in Virtual dub (but you may keep VirtualDub open):
1.Open the registry [HKEY_CURRENT_USER] and find:
Software/DivXNetworks/DivX4Windows/State
2.For above Codec you'll see here the entry:
06_01_01_01031_Tiger_WinCodecArtwork
containing last valid CLI values like:
-bvn1 1000000 -vbv 4854000,3145728,2359296 -c 8,16,40,40...
3.In this example, values "-c 8,16" define crop area (8=left, 16=right).
4.Now you manually change only those values to:
-c 32,32 (leave all other values unchanged)
Now again, in VirtualDub open menu Video>Compression... and try to select DivX 6.1.1 Codec -VirtualDub can't find it anymore! If you restore values in registry, VirtualDub will find DivX6 codec again.
So... where's the bug?
Greetings,
Bogdan
PS: I'm not a member of all possible software forums (to post "official bug report"). If somebody has time to proof above issue, please give a notice to appropriate forum. Thanks
Results 1 to 1 of 1
VirtualDub + Crop Filter adds a black border in right corner of video?
By CactusMan in forum Newbie / General discussionsReplies: 5Last Post: 17th Jan 2010, 08:24 -
is it possible to crop a WMV file with virtualdub mod?
By sumeshkri in forum EditingReplies: 4Last Post: 13th Nov 2008, 21:26 -
Box crop for virtualdub
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 6th Sep 2007, 11:06 -
DivX3 to DivX6???
By npresto in forum Video ConversionReplies: 3Last Post: 28th May 2007, 18:49 -
Subtitles in DivX6
By nowhere in forum EditingReplies: 0Last Post: 20th May 2007, 09:42
