I have an AVI file encoded with the h264 codec. I am trying to get this to DVD. Its resolution is 512x224 (yes, odd res). I've tried so many ways to get a proper encoding it's not even funny. The methods I've used that look good in terms of quality screw up in some other way. Here are some ways it has happened, each one a different problem, never at the same time:
Video inverted, upside down
Video stretched vertically
Video cut off at the sides
Video contains patches of garbled noise
The last one is coming from TMPGEnc. It's the only encoder/converter that isn't causing the above 3, and instead it causes this. I'm starting to run out of ideas. If I could just get it out of this awful (for me) codec, I could probably work with it a lot better, but I don't know what it is to cause so many different problems, only different between different encoders. I've so far given it a try with Aurora, WinAVI, TMPGEnc, WinDVD Creator, and Blaze Media Pro. All of these causing one of these problems.]
Where should I start the troubleshooting at the point I've reached?
my problem currently with TMPGEnc is the bits of garbled noise that appear all throughout it every few frames. This is something ONLY TMPGEnc has been producing, too. On the other hand, this seems to be the only thing TMPGEnc is doing wrong, whereas all the other encoders/converters have been doing the other, "simpler" problems.
i would try avisynth and frameserve to tmpgenc, read
https://forum.videohelp.com/viewtopic.php?t=284288
What form of h264 will VideoRedo h264 tvsuite accept?
By Asterra in forum Video ConversionReplies: 4Last Post: 12th Apr 2012, 14:22 -
Problems converting some xvid to h264 to append to another h264
By PlanetIndigo in forum Video ConversionReplies: 3Last Post: 6th Jun 2011, 15:13 -
H264 and mkvtoolnix for Youtube woes
By mindwalker in forum Video Streaming DownloadingReplies: 8Last Post: 21st Dec 2010, 15:59 -
H264/AC3 (MKV) to H264/AAC (MP4) ?
By jccca in forum Video ConversionReplies: 10Last Post: 13th Dec 2008, 20:06 -
H264: Are there other h264 (AVCHD/VC-1) encoding command-line/CLI tools ??
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 16th Feb 2008, 02:20
