How do you save Templates in TMPGenc ?? I have tried several times, and it won't keep the settings I used..
HELP !!!!!!!
Just click on "save". Give your template a name, and choose as path the template folder within the TMPGEnc folder. Now close TMPGEnc and re-open. Now click on "load" and select the template you have saved before. The only thing which will not be saved is the "advanced" tab.
The Dutchman
Saving/capture solutions for saving off (extending) DVR
By ET3D in forum Newbie / General discussionsReplies: 1Last Post: 28th Oct 2011, 18:13 -
templates for Corel VideoStudio X3?
By wingfan in forum EditingReplies: 2Last Post: 25th Feb 2010, 14:10 -
DVD templates
By anfield7 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Dec 2007, 01:16 -
DVD Templates and encoding
By Canadian* in forum Authoring (DVD)Replies: 2Last Post: 24th Sep 2007, 18:11 -
How To Install Templates into StaxRip
By Trac in forum User guidesReplies: 0Last Post: 7th Jul 2007, 01:23
