I am looking at my friend's old pc, when I start it it says Invalid system disk, Replace the disk and then press any key.
I can enter dos with my win 98 startup disk.
I loaded a new window xp cd and it will not even start, I even changed to boot from cd-r first.
It sound like a bad hard-drive? What do you guys think?
Are you using a startup disc with cd rom support?
I know Win98SE and higher have that option.
Chas -
When you say that you can enter DOS with the win98 boot disk, do you mean that you can access the C drive of the computer in question?
If that is the case then all you should have to do is do a sys c: command to copy the system files back on to the hard drive, then it should boot just fine -
Loose IDE cable?
Believing yourself to be secure only takes one cracker to dispel your belief.
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
Restore disk image on different operating system
By r3n4ud in forum ComputerReplies: 7Last Post: 1st Sep 2009, 09:44 -
cloning winXP system disk problem
By deejay.2001 in forum ComputerReplies: 1Last Post: 15th Jun 2009, 15:54 -
Disk Cleanup Missing in System Tools
By bevills1 in forum ComputerReplies: 4Last Post: 7th Jun 2009, 17:30
