  1. I was playing around with some dv codecs and lost my original sony dv codec v2.26. I still have the sonydv.dll in a program folder but cannot get my computer to recognize it. How can I install it? I tried to use regsvr32 but keep getting an error.
  2. Member zoobie's Avatar
    Feb 2005
    Florida
    try right clicking on it and clicking install
    May 2003
    Peterborough, England
    Or System Restore to before you messed with the codecs.
  4. I does not give an option to install.
    I tried to system restore but it will not allow me to. I think my restore point got corrupted.
  5. Mod Neophyte redwudz's Avatar
    USA
    Or you can use the Panasonic DV codec. It comes with instructions:
    http://users.tpg.com.au/mtam/install_panvfwdv.htm
  6. Ok I think I fixed it. I used an installer for version 2.23 and intalled that version. I then copied version 2.26 and pasted it in the system32 folder replacing version 2.23. This shouldn't screw up anything should it?
  7. Originally Posted by magnus
    Unlikely. It should be fine.
