Greetings,
I capture movies on an ATI AIW to mpeg2 files, divided into 1GB segments. I wish to make these into DVD's. My question is;
Must I convert these into DVD format, since DVD is mpeg2 anyway or can I just go straight to the authoring step?
Believe it or not, I did spend many hours pouring over different forum entries, faq's and articles, but still not clear.
Thanks for any help.
JimS
if the mpeg2s are dvd compliant you can author directly,
www.videohelp.com/dvd#tech or just test add them in for example tmpgenc dvd author and it will tell you if they are dvd compliant -
mpeg2 can be DVD compliant or can be in any number of oddball resolutions and aspect ratios. Have a look at What Is DVD at the top left, look up the DVD compliant resolutions (ie 720 x 480, 352 x 480, etc) and capture in one of those. You will then just be able to go straight to the authoring stage.
Can you make a Blu-Ray with MPEG2 format?
By faramith in forum Authoring (Blu-ray)Replies: 5Last Post: 18th Jan 2011, 02:39 -
MPEG2 with LPCM -> ? (less MB demanding format)
By Zetti in forum Video ConversionReplies: 3Last Post: 15th Sep 2010, 14:12 -
converting Dv-Avi/Dvd Mpeg2 to Xvid format
By glenpinn in forum Video ConversionReplies: 56Last Post: 9th Jun 2009, 10:23 -
Recent recorded hom evideos to DVD now in Mpeg2 format... what to do?
By tehfreeman in forum Video ConversionReplies: 2Last Post: 19th Dec 2008, 13:07 -
Capturing - to what format, DV or MPEG2.?
By Airjrdn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 28th May 2008, 07:45
